Digital I/O
Programming DAQ Board using C++ Builder 6.0
"Hello,
I'm trying to program PCI-DIO-32HS using C++ Builder 6.0 and DAQ driver 6.9.3 in Windows XP.
I added nidaq32b.lib and nidex32b.lib to my C++ project, and compiled C++ file slightly changed from Borland C example, but always got the error message related with something of initialization.
So I made lib files from the start using implib command, but got no results either.
Could anyone let me know the another way?"
(3,360 Views)
Make sure you add the include and library paths to your C++ directory paths. Are you getting compile errors or run-time errors? I would also try running some of the shipping examples for the PCI-DIO-32HS.
Joshua
(3,360 Views)
