Digital I/O
External Trigger Source For Digital Output
Hello All,
I'm not sure if this question has been posted before, but I haven't found it. Also I am kind of new to LabVIEW as well.
I have a NI cDAQ-9178 with an NI 9403 and an NI 9923. I also have a machine that generates a pulse wave that is high at 3.3 V and low at 0 V.
I am trying to have a digital output go high when the external pulse goes high. When I try to set a trigger, I cannot use the DIO lines in the NI 9403. I tried to trigger when a digital pattern is recognized, but I kept getting an error. I then looked online and found that maybe the device does not support it. I then tried to start the trigger by a digital edge. But I didn't see any option to use a specific line as a trigger source. So what I did is that I connected the wire into the PFI 0 port. Using this and an oscilloscope, I was able to generate and verify that the signal was high when the pulse went high.
The problem is that I will eventually need to monitor 3 separate pulse waves and have 3 separate lines generate an output instead of 1 and there are only 2 PFI ports on the Ni cDAQ-9178. So I was wondering if there was any way to do this without using the PFI ports with these devices?
Thanks in advance!
(4,436 Views)
Hello slrarick,
Digital triggering is not supported by the NI 9403 module.
Bye
(4,409 Views)
