Digital I/O
sinking and sourcing inputs
Whats the application difference between sinking and sourcing inputs?
I know that sinking inputs just provide a path to to ground for current, and sourcing inputs provide a path to the + end.
I do not understand the application benefits and negatives of sourcing/sinking. When would I want a sourcing input and when would I want a sinking input?
(4,899 Views)
Obviously it depends on the outputs you connet to the input.
Also if the outputs (also switches) have a common  '+'  or common  '-'  connection.
Kees
(4,882 Views)
If you have NPN or PNP type devices in your application, choosing of sinking or sourcing inputs from the start would get your job easier.
(4,856 Views)
