Digital I/O
FPGA I/O Read/Write Time
I have a general question about FPGA digital I/O nodes.  I am using a cRIO module which does not support SCTL for DIO read/write, so I have placed the read/write in a while loop.  My question is how many cycles do these read/write commands take?  I can't find this information in any documentation I have searched.
The reason I ask is that I am using a Loop Timer vi to run the while loop at a certain rate, and I am concerned that under certain circumstances when my read/write commands are made near the end of the loop period that they might cause it to run over.  Here is a simplified version of my FPGA vi.  It is begin used to generate a centered-pulse PWM signal.  Thanks.cntrdPWM.PNG
(4,413 Views)
You should just benchmark the code.  It will be super easy and then you will know for sure.
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(4,407 Views)
