Digital I/O
FPGA : a long time to download VI
I want to dowload a FPGA VI to my PCI 7831R device.
To compile the VI, it takes 25 minutes. No error is found. When I want to dowload it to my Device, it is written "dowload progress" but nothing progress. Nothing else happened even if I wait 30 minutes or more.
I can't download any VI to my device.
Where is the problem?
Message 1 of 8
(8,269 Views)
Well it is difficult to answer you with these information.
Could you tell me if :
1. you see any "RIO Devices" in MAX.
2. you can launch "Download VI or Setup PCI-7931R" in the Windows Start Menu "... >> National Instruments >> NI-RIO >> PCI-7831R".
I will be able to help you more.
Regards.
Benjamin
National Instruments France
Message 2 of 8
(8,250 Views)
Hello Benjamin,
1 . I see RIO Device in Max (RIO0 : INSTR). My device is FPGA ( PCI-7831R).
But I see my device too in Max in PXI System (unidentified).
2 . I can launch "Download VI or Setup PCI-7931R" in the Windows Start Menu "... >> National Instruments >> NI-RIO >> PCI-7831R".
But when I launch it, I choose the VI and the same problem is on. A message is "download progress" but nothing else.
Message 3 of 8
(8,228 Views)
Hi Walla,
Did you already try to reinstall the drivers? If you didn't, it would be nice to try it.
To reinstall the NI-RIO drivers :
1. Uninstall NI-RIO drivers from the "Add/Remove Softwares",
2. Power off your computer and unplug your PCI-7831R,
3. Power on your PC and reinstall the last NI-RIO drivers,
4. Power off you computer and plug in your board again,
5. Power on you computer and try to download a VI on the board,
If you have the opportunity to test your PCI-7831R in another PC, try to test it.
I hope this will help you to solve your problem. If it doesn't, please provide me the versions of: the operating system, the NI-RIO drivers, LabVIEW and the LabVIEW FPGA module.
Benjamin
Message 4 of 8
(8,189 Views)
I try but I have the same problem.
I think, perhaps it's a problem of memory. I don't have got 512 M of RAM.
Message 5 of 8
(8,140 Views)
Did you try to download a small example?
You can find examples with the "NI Example Finder" tool from the LabVIEW menu "Help >> Find Examples...". Just go to the "Toolkits and Modules >> FPGA" folder.
Please let me know if the test is successful or not.
Best regards.
Message 6 of 8
(8,128 Views)
I try but I have the same problem. I try to add memory but then, with my FPGA device, I can't start my computer.
I can start it with less memory (RAM) but with 512 M and my FPGA device, I can't start it.
I have to remove the FPGA device to start my computer with 512 M of RAM.
With less memory, I can't download any program.
Message 7 of 8
(8,118 Views)
It would be better to discuss your problem by phone. Please contact National Instruments France and ask for the technical assistant. Your service request number is 224704.
Message 8 of 8
(8,113 Views)
