Digital I/O
Flipping state of output after every 3 cycles of while loop
I am trying to flip the state of output after every 3 cycles of while loop.  At this point, the code would look like this:
if  i_quotient_of_while_loop_iterator == 0
then output_1 = not output_1
It seems like there is no way to do if, how can I accomplish this
(4,633 Views)
What language are you using? It's trivial in LabVIEW with the Quotient & Remainder function. Other languages have a Mod() function which does the same thing.
(4,631 Views)
I am very new to LabView, but I believe i am creating the block diagram for VI.  Yes, I did try to use quotient&remainder, and the output does blink, but it only turn on for 1 cycle, but I need 3 cylces on and 3 cycles off.  See the attached picture of screen capture.
(4,625 Views)
Accepted by TimSit
TimSit,
This is one way to do this.
(4,608 Views)
Very Elegant, thank you...
(4,593 Views)
Three cycles at one logic level at a rate of x sec is the same thing as 1 cycle at a rate of 3x sec? I don't understand the point.
(4,587 Views)
The program is only a portion of the whole picture, 1 second domain is required to do other functions.
(4,584 Views)
