Digital I/O
Flipping state of output after every 3 cycles of while loop
I am trying to flip the state of output after every 3 cycles of while loop.  At this point, the code would look like this:
if  i_quotient_of_while_loop_iterator == 0
then output_1 = not output_1
It seems like there is no way to do if, how can I accomplish this
(4,621 Views)
What language are you using? It's trivial in LabVIEW with the Quotient & Remainder function. Other languages have a Mod() function which does the same thing.
(4,619 Views)
I am very new to LabView, but I believe i am creating the block diagram for VI.  Yes, I did try to use quotient&remainder, and the output does blink, but it only turn on for 1 cycle, but I need 3 cylces on and 3 cycles off.  See the attached picture of screen capture.
(4,613 Views)
Accepted by topic author TimSit
TimSit,
This is one way to do this.
(4,596 Views)
Very Elegant, thank you...
(4,581 Views)
Three cycles at one logic level at a rate of x sec is the same thing as 1 cycle at a rate of 3x sec? I don't understand the point.
(4,575 Views)
The program is only a portion of the whole picture, 1 second domain is required to do other functions.
(4,572 Views)
