Digital I/O
Freeing DMA channels
I am using pattern gen. single buf. input on a 6533 with Win2k and Borland C++ v5. When the program using the board (via NI-DAQ, the latest version) dies badly, it does not seem to free the DMA channel that the board is using. I get the "No DMA channel available for use" error when I run my program again. This means that I have to reboot.
How can I free the DMA channel used by the 6533 without rebooting? I have tried to use DIG_Block_Clear at the start of my program, but it complains that no transfer is in progress.
(3,533 Views)
Hi, this command has been useful to me in reseting my devices when they get in an unstable state "status = DAQ_Clear (deviceNumber);". It should work at reseting all the resources including the DMA channels. Hope it helps.
Ron
(3,533 Views)
DAQ_Clear is for DAQ devices, not DIO devices. I get an error -10403 "Device does not support the requested action" when I try this function.
BTW: I mistankenly said I had a 6533; I actually have a PCI-DIO-32HS (they are pretty much the same thing, the 32HS uses PCI instead of PXI).
(3,533 Views)
You are absolutely right. The command we want to use is Init_DA_Brds. This happens to be the command the the driver uses at startup to reinitialize all the boards. Hope that helps.
Ron
(3,533 Views)
