Digital I/O
Generating pulse output using 6212
I am working on usb 6212 to generate pulses from this boad to drive stepper motor.i have to drive multiple stepper motors(using L298) through this board so i need many pins to genrate stepper motor driving sequence pulses.i have tried generating pulses using delay and switching the port pins alternately.but i am not able to generate high frequency pulses by doing so.will be gratefull to get ur help in solving my problem
satvir
(3,683 Views)
Look to my simple procedure (delphi)
procedure TForm1.Button2Click(Sender: TObject);
var
 NumPoints:integer;
 der:integer;
 maxfreq:double;
 rate:real;
begin
rate:=1000;
Error:=DAQmxCreateTask('',@cnt0Handle);
MemoStatus.Lines.Add('Create cnt0 Task: status error'+IntToStr(Error));
Error:=DAQmxCreateCOPulseChanFreq(cnt0Handle,'Dev4/ctr0','',DAQmx_Val_FrequencyUnits_Hz,DAQmx_Val_Low,0.0,rate,0.50);
MemoStatus.Lines.Add('Create COPulse: status error '+IntToStr(Error));
Error:=DAQmxCfgImplicitTiming(cnt0Handle,DAQmx_Val_AcquisitionType_ContSamps,nr_sample);
Error:=DAQmxCfgImplicitTiming(cnt0Handle,DAQmx_Val_AcquisitionType_FiniteSamps,100);
MemoStatus.Lines.Add('Cfg Implicit Timing: status error '+IntToStr(Error));
  Error:=DAQmxGetDevCOMaxTimebase('dev4',@maxfreq);
  MemoStatus.Lines.Add('Cfg Implici Timing: status error '+IntToStr(Error));
  MemoStatus.Lines.Add('Max Freq: '+FloatToStr(maxfreq));
  Error:=DAQmxCreateTask('',@DOHandle);
  MemoStatus.Lines.Add('Create DO Task: status error '+IntToStr(Error));
  Error:=DAQmxGetDevDOMaxRate('dev4',@maxfreq);
  MemoStatus.Lines.Add('Max Freq DO: '+FloatToStr(maxfreq));
  Error:=DAQmxCreateDOChan(DOHandle,'Dev4/port0','',DAQmx_Val_ChanForAllLines);
  MemoStatus.Lines.Add('Create DO Chanel: status error '+IntToStr(Error));
  Error:=DAQmxCfgSampClkTiming(DOHandle,'/Dev4/Ctr0InternalOutput',rate,DAQmx_Val_Rising,DAQmx_Val_AcquisitionType_FiniteSamps,nr_sample);
  MemoStatus.Lines.Add('Sample Clk Timing: status error '+IntToStr(Error));
  Error:=DAQmxWriteDigitalU32(DOHandle,nr_sample,True,10.0,DAQmx_Val_GroupByChannel,@data[0],@writter,nil);
  MemoStatus.Lines.Add('Write Digital: status error '+IntToStr(Error));
  Error:=DAQmxStartTask(cnt0Handle);
  MemoStatus.Lines.Add('Start Cnt0: status error '+IntToStr(Error));
end;
(3,618 Views)
Are you using LabVIEW?
(3,600 Views)
