Digital I/O
NI 9485 Port0/Line1 not switching via Diadem
I´m tying to get two SSR Outputs swichting, depending on incoming Signals.
Port0/Line0 is working but Port0/Line2 is doing nothing. (I also tried Line1)
I´m using MAX 4.6.2f1 Diadem 10.2, the channels are defined in DAQmx and can be choose in Diadem.
Any Ideas?
(3,489 Views)
Hello Beenken,
could you please provide some more details:
1. what is your setup, what are your inputs/outputs, which hardware do you use
2. attach your DIAdem-DAC curcuit
3. technical MAX report
4. what is the concrete purpose of your curcuit
Thanks in advance
(3,458 Views)
Sorry - my fault... I fixed the problem
(3,454 Views)
