Digital I/O
Generation pattern whith PCI6534
Is the PCI 6534 able to generate un pattern on each trigger pulse in continuous mode ?
I have tried to configure the board in Continuous mode with external trigger but the pattern is only synchronize on the first trigger pulse.
(3,668 Views)
If you need it to generate one sample per trigger, you can use the trigger as a sample clock.
(3,654 Views)
This is not what I want to do.
I have to generate a complet pattern (220 bytes) at 1 MHz on each trigger pulse (250Hhz). I use the internal clock for rate transfert at 1Mhz, this is OK but the problem is to synchronize each transfert on a trigger.
A french National Instrument engineer tell me that this board is not able to do this.
I have tried another solution, a software solution :
I have created a thread that call in loop the 'DIG_Block_Out()' method but now my application is very low.
(3,652 Views)
Indeed the PCI-6534 does not support retriggering. Nevertheless, you have another solution.
In order to perform a retriggerable pattern generation operation, you must put the board in continuous generation mode and use an external clock. This external clock should be gated such that upon receiving a trigger, it generates the same number of pulses as there are words in the pattern and then stops. Upon receiving a second trigger, the process repeats. The counters on an E series board can be made to function in this fashion.
(3,614 Views)
