Digital I/O
HSDIO DAQmx Examples
Hello all,
Are there any examples of the HSDIO card being programmed with the DAQmx library? I want to be able to use DAQmx and HSDIO libraries and cannot find any DAQmx examples for me to leverage against.
Thanks for any help and examples!
Minesh
(6,838 Views)
Also,
My HSDIO card is the PXI-6542
Minesh
(6,837 Views)
Hi Minesh,
The 6542 cannot use the DAQmx API.  We don't currently have any devices that can use both the DAQmx and the HSDIO API; it's an either/or relationship.  We do have a few modules that we consider High Speed Digital I/O that use DAQmx instead of HSDIO.
To see what hardware is supported by DAQmx, go to the Start Menu >> All Programs >> National Instruments >> NI-DAQ >> NI-DAQmx Help.
To see what hardware is supported by niHSDIO, go to Start Menu >> All Programs >> National Instruments >> NI-HSDIO >> Documentation >> NI Digital Waveform Generator-Analyzer Help.
Josh B
(6,823 Views)
Thanks Josh,
I make a mistake in my HSDIO number, we have the PXI-6541. Does the same limitation hold true?
Minesh
(6,818 Views)
Accepted by topic author Minesh
Hi Minesh,
This holds true with the 6541 as well.  It is compatible with the HSDIO API, but not DAQmx.
Josh B
(6,806 Views)
Thank You!
(6,803 Views)
