Digital I/O
How can I get digital output on usb of Lap?
I want to generate 5V on D+ of USB of lap.
Can I use Daqmx, Visa Control Out, or any thing else?
(5,390 Views)
Khaled88,
You cannot control the 5V USB power line with VISA commands in MAX. This is a bus standard and the USB port will always port out +5V. You could wire the 5V output into a relay and control it that way, but you will not be able to toggle this line on/off with any NI software.
Best,
Jason M.
(5,367 Views)
