Digital I/O
Handshake question
Hello
Sorry for the spam but I have a very simple question that I haven’t been able to find an answer to:
I need to read in some data to a computer from an ADC I already have.
The communication is a parallel connection and should work as follows:
The ADC puts the binary number on the data lines when it is ready it activates the ready line.
When the computer sees the ready line it should read the data lines, transfer it to a buffer and then activate an Acknowledge line.
After which the ready and Acknowledge lines are deactivated.
This should then be repeated and possibly quite fast so I would like it to be done without direct interaction of the control program and only by reading the buffer.
When I read about different IO cards I would like to call this handshake is this correct or does it mean something else?
If a card is specified as supporting handshake does it then automatically support the buffer part or should I look specifically for this too?
Thank you for your help
Per
Message 1 of 1
(4,040 Views)
