05-27-2019 02:15 AM
Please be kind enough to teach me how to how make 13.56MHz gate driver signal using myRIO-1900
Solved! Go to Solution.
05-28-2019
05:01 PM
- last edited on
01-08-2024
02:37 PM
by
migration-bot
Hey,
Are you familiar with our FPGA programming? What specifically are you trying to program? What kinds of inputs are you expecting from your IC?
05-29-2019 01:43 AM
Thank you for your reply on this matter.
I am not familiar about NI FPGA Programming. My Laboratory is a Power Electronic Laboratory in my University. I brought MyRIO-1900 to introduce to my Laboratory for all the power electronic experiment in our laboratory. Our Laboratory use Gate Driver Signal Frequency from 10kHz to 30MHz. In my research, I want to design a PWM signal with 13.56MHZ to drive the GaN device in the Full-Bridge Inverter. (Input signal to the drive IC should be a 13.56MHZ PWM signal).
Please be kind enough to help me to design the above control signal.
Thank you.
