Digital I/O
Manchester Bits generation
Hi!
I am trying to generate a Manchester code through a digital output of the PXIe-6612 module.
In the attached VI, I am able to generate a Manchester code over 1ms clock. This means that as each bit is encoded in a low-to-high or high-to-low transition, each bit actually takes 2ms to transmit.
The thing is that I have to generate the signal with a period of 500us --> I would need to execute the loop every 250us.
Which is the best way to do this? I am a newbie in LabView.
Any assistance would be appreciated.
Message 1 of 11
(3,899 Views)
Accepted by topic author Erlie
You will need to create a digital waveform task and output that through the DIO board.  This takes the timing away from your software (which will be slow) and puts it on your board (which is actually made for this).  Open the example finder (Help->Find Examples) and go to Hardware Input and Output->DAQmx->Digital Output->Digital - Finite Output.vi.  That example should be what you are looking to do.
Message 2 of 11
(3,882 Views)
Thank you very much for answering!
Actually, I have taken the "Digital - Continuous Output.vi" example, as I would like to generate the same code continuously, so I think that this example would fit me better. Am I right?
First, I am trying to make the example run in my HW, and then, to modify it to adapt it to my needs.
But, I think that there is something that I don´t understand in the example, since I can´t configure it correctly so that I can see that the outputs change their values.
The configuration that I am using is the following for PXIe-6612, which in my case is in Slot 2:
  • Line(s): PXI1Slot2/port0/line8:14
  • Sample Clock Source: /PXI1Slot2/PFI0
  • Sample Rate: 1000
  • Number of Samples: 1000
Please, could you tell me what I am not configuring well?
Message 3 of 11
(3,872 Views)
You configured your task to use a signal at PFI0 as your sample clock.  Have you routed such a signal to PFI0?   You'll need to, otherwise there won't be a clock-like signal (a digital pulsetrain) there.
-Kevin P
Message 4 of 11
(3,868 Views)
How can I route a sample clock to PFI0?
Or, is there any better way of using an internal sample clock directly?
I´m sorry, but I´m new in LabView.
Message 5 of 11
(3,857 Views)
Lucky you, your device is a newer design that can derive its own sample clock for DO tasks.  So if you're working on a modified version of the shipping example, you can just select "OnboardClock" and DAQmx will figure out the rest for you.  (The same would be true if you simply left the corresponding input on DAQmx Timing.vi unwired.  That would tell DAQmx to do the default thing, which is to derive a sample clock from its internal timebase.)
-Kevin P
Message 6 of 11
(3,854 Views)
Thank you very much for your reply Kevin!
I have configured it as "OnboardClock", but the output doesn't change. I should be doing something wrong, I don't know if it is in SW, HW...
Attached you will find the vi I am using. Any idea?
Message 7 of 11
(3,844 Views)
I forgot to attach the vi, here it goes!
Message 8 of 11
(3,842 Views)
No errors though, right?
As posted, the default value of the 'number' control is 0, leading to an unchanging stream of 0 values (False) being generated.  Did you run it with any non-0 bits in the 'number' control?
What are you doing to try to detect changing bits?  The default sample rate is 1000 Hz, so you wouldn't be able to see distinct changes if you're probing the output voltage with a multimeter for instance.
-Kevin P
Message 9 of 11
(3,809 Views)
Yes, of course I have run the vi with different non-0 "number" values, but even the program runs without any error, the output doesn't change. I'm measuring the output with an oscilloscope and I'm expecting signal at 1ms period. The signal I see is a constant 0.
In case of executing the vi that I attached in the first comment of this thread (DigitalOutput_ManchesterBits.vi), I do see that the output signal changes.
Any idea of what I'm missing in "DO_ContinuousGeneration.vi"?
My aim is to generate a Manchester code type signal from an input value (number). But as a first step, I want to be able to generate a signal continuously. Once this is done, I will modify the "number" array to adapt it to Manchester code.
Message 10 of 11
(3,780 Views)
