Digital I/O
How I can use Labview 8.0 to Control the bits of control register for EPP/ECP parallel port?
I am trying to be able to control the bits of control register for EPP/ECP - Parallel Port using Labview 8.0. The Parallel port read and write program provided at NI examples can only used to control SPP. The reason why I am trying to control those bits is that I plan interface a LCD through EPP/ECP. And I need be able to control total 10 bits in order to program the LCD I have. Please help!
(3,653 Views)
Hello!
The following document should be able to help you.  It is a little bit lengthy but gives you a few different ways to do what you are looking at doing.  Please let us know if you need any more information.
http://digital.ni.com/public.nsf/allkb/B937AC4D8664E37886257206000551CB?OpenDocument
Scott G.
AE Specialist
(3,633 Views)
