05-22-2009 01:19 AM
05-22-2009 01:23 AM
05-24-2009 10:01 PM
1. if the frequency of gate signal and source signal are fixed, you can use finite generation and retriggerable start trigger mode to accomplish this.
2. U can configure a counter output 20k hz signal and route the 20 hz gate signal as start trigger and pause trigger.
hope it may help.
05-25-2009 02:55 AM - edited 05-25-2009 02:57 AM
Thank you.
But i can't regenerate a 20K Hz signal. I must use the original signal, because this signal is an synchronous signal between two equiments.
