Digital I/O
How can I use the NI PXI-6508 with Lab View 7? what are the first steps to get started??How can I use the channels with lab view 7????
I have a 8 slot PXI system with 2 NI PXI 6508 and 1 DMM 4070 in it. I want to get started with programming the digital I/O cards (6508)! How can I use this cards with LabView 7?what is the best way to get started, or where can I get examples showing how to use the several channels?
Thanks!
Philipp
(3,616 Views)
Philipp,
The best way to get started is to decide if you want to use traditional NI-DAQ or NI-DAQmx. Recently we released NI-DAQ 7.1 which provides NI-DAQmx support for the PXI-6508. In my opinion, NI-DAQmx is more efficient and much easier to use.
To get started with examples, simply launch LabVIEW and go to Help>>Find Examples. Then expand Hardware Input and Output>>DAQmx and select the appropriate digital group for your application. This should help get you started.
Please repost if you need addition assistance. Good luck with your application!
(3,616 Views)
