Digital I/O
using the same wire for positive edge start trigger and negative edge stop trigger for 6533
I would produce a start trigger for an external data source to start them.
Emediatly after this starttrigger this source produces a trigger Signal.
I would like to use this trigger Signal as an extern trigger which should provide some functions:
1. on the positive edge of the Signal some pattern should read in with an external clock.
2. on the negative edge of the trigger signal this process should stop.
I would do this with CVI
(3,277 Views)
Hey Schicki,
I have included two links below that should help you with your application. The first one is setup to perform digital pattern I/O with an external clock in CVI. The second shows how to incorporate start/stop triggers in digital pattern I/O operations. You should be able to combine parts of these two programs to complete your application.
NI 6534 Double-Buffered Pattern Generation, External Clock -- CVI
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E7FD56A4E034080020E74861&p_node=DZ52321&p_source=External
Output Digital Data from a Buffer to a Group of Two Digital Ports Upon a Digital Start Trigger
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3EA4556A4E034080020E74861&p_node=DZ52321&p_s
ource=External
I hope this helps.
Todd D.
NI Applications Engineer
(3,277 Views)
