Digital I/O
How can I use the NI USB-6259 BNC's internal clock for digital data acquisition in my own big software?
I want to integrate the ANSI C Example program ReadDigPort-ExtClk.c into my own big software package.
I want to use the NI USB-6259 BNC's internal clock (80 kHz .. 120 kHz).
In document:
High-Speed M Series Multifunction DAQ for USB - 16-Bit, up to 1.25 MS/s, Integrated BNC Connectivity
is written:
DO or DI Sample Clock source: Any PFI, RTSI, AI Sample or Convert Clock, AO Sample Clock, Ctr n Internal Output, and many other signals
The digital subsystem does not have its own dedicated internal timing engine. Therefore, a sample clock must be provided from another subsystem on the device or an external source.
With which other subsystem on the device can I generate a clock source? How?
It is possible to define a clock on an internal counter  (e.g. "Dev1/ctr0"):
// Creates channel(s) to generate digital pulses that freq and dutyCycle define and adds the channel to the task you specify with taskHandle.
DAQmxCreateCOPulseChanFreq(taskHandle, "Dev1/ctr0", clockName, units, idleState,
        initialDelay, freq, dutyCycle); // works
But it is not possible to drive this internal clock to a terminal (e.g. "/Dev1/PFI0"):
DAQmxErrChk (DAQmxCreateCOPulseChanFreq(taskHandle, "/Dev1/PFI0", clockName, units, idleState,
    initialDelay, freq, dutyCycle); // doesn't work: DAQmx Error: Measurements: I/O type of the physical channel does not match the I/O type required for the virtual channel you are creating. Physical Channel Name: PFI0 . Virtual Channel Name: Clock
The source of the Sample Clock may be derived from an external terminal (e.g. "/Dev1/PFI0"):
// Sets the source of the Sample Clock, the rate of the Sample Clock, and the number of samples to acquire or generate.
DAQmxCfgSampClkTiming(taskHandle, "/Dev1/PFI0", maximumExpectedSamplingRate, DAQmx_Val_Rising,
        DAQmx_Val_ContSamps, bufferSize); // works. Acquire or generate samples until you stop the task
But it is not possible to derive the clock from the internal counter (e.g. "Dev1/ctr0"):
DAQmxCfgSampClkTiming(taskHandle, "Dev1/ctr0", maximumExpectedSamplingRate, DAQmx_Val_Rising,
      DAQmx_Val_ContSamps, bufferSize); // doesn't work. Error: Acquire or generate samples until you stop the task : Make sure the terminal name is valid for the specified device. Refer to Measurement & Automation Explorer for valid terminal names. Property: DAQmx_SampClk_Src Property: DAQmx_SampClk_ActiveEdgeSource Device: Dev1 Source Terminal: Dev1/ctr0
(4,789 Views)
Accepted by datafriend
Hi datafriend,
what the help says is correct:
That means if you don't want to use an external signal as clock you can use the onboard AI Sample clock or the internal counter output.
There are also 2 ANSI C Examples for this:
http://zone.ni.com/devzone/cda/epd/p/id/4485
http://zone.ni.com/devzone/cda/epd/p/id/4488
So in both cases you have to use a dummy task which you only need for the generation of the internal clock (AI or CTR)
Regards
DianaS
(4,775 Views)
Hello DianaS,
with your hint to the examples I could solve the problem.
Thank you very much.
Best regards
datafriend
(4,710 Views)
