Digital I/O
How do I configure 128 channels of DIO and 128 channels of Analog output with the availability of 3 pci slots
I have only 3 slots of PCI or 4 slots of ISA bus, I want to configure with the minimum possible modules to attain 128 channels of DIO and 128 channels of analog output. This is inturn fed to the PCM (Pulse code Modulator). The cards will be placed in industrial PC.
(3,233 Views)
Associate Engineer-Marketing,
Using just those 3 PCI slots you're not going to be able to get the 128 analog output channels. You will probably want to go either the MXI-3 (PCI bus extender) to a PXI chassis or E Series DAQ card to a SCXI chassis for such a high channel count system. Which analog output cards and which digital I/O cards you will want depends on your application. You will have to decide whether you will need static or dynamic analog output as well as whether you need clocked digital I/O or not. I highly recommend contacting our internal sales department at 1-800-433-3488. They are great at helping specify systems.
Ames
Applications Engineering
(3,232 Views)
