Digital I/O
how to specify sample rate of DIO using PXI6733
I am using PXI6733 to collect data, and run the simulation program on real time target controller. I need to specify the sample rate of DIO near 2MHZ, but I don't find the right block to specify the rate. Anybody could give me an example or hint?
(3,168 Views)
Braver,
Because the NI 6733 does not have a digital clock, you will need to use an external clock, the output of a counter, or the AO update clock. This topic is detailed in the following KnowledgeBase. Specifically, it provides the location of applicable examples.
Performing Hardware Timed Buffered Digital Operations with the NI-6115, NI-6120, and NI-6733
Good luck with your application.
Spencer S.
(3,168 Views)
