04-16-2002 05:53 PM
04-17-2002
02:16 PM
- last edited on
07-24-2025
09:12 AM
by
Content Cleaner
You can find how to use the onboard memory of the NI-6534 on page 2-9 of the 653x User's Manual
In general, you will have to use Set the ND_PATTERN_GENERATION_LOOP_ENABLE to ND_ON
in the Set_DAQ_Device_Info function.
On the function panel for the function Set_DAQ_Device_Info there is no option for ND_PATTERN_GENERATION_LOOP_ENABLE, you have to type it manually and also you have to type the information value. It works, just do not use the D at the end of the ENABLED word from the User's Manual!
Good luck with your application! Hope this information helps.
