Digital I/O
How do I time the on state of a signal
I have no LabView experience and have inherited a project. I simply want to record the time that a digital input is true and have the facility to reset the time back to zero for the next run. I found a stop watch VI but cannot modify it so that it:
will run when the signal is true
stop when the signal is false
Has a reset function to reset the accumulated time to zero
(3,717 Views)
I have written an example VI that should contain the functionality that you require.  I understand that you have little or no experience with LabVIEW, so please don’t hesitate to contact me if anything is unclear in the code.
I look forward to hearing from you.
Ian
(3,684 Views)
Thanks Ian but unfortunately I can't open the VI. I am working on version 8.2.1
(3,668 Views)
Sorry about that. This VI should run on your system.
Ian
Message Edited by Ian Colman on 10-12-2007 04:48 AM
(3,665 Views)
Thanks Ian
That will do nicely
(3,644 Views)
