Home
Community
Discussion Forums
Most Active Hardware Boards
Digital I/O
Topic
Digital I/O
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How do I with c++ generate SPI from a PXI 6534 ?
JohanR
11-29-2005
08:06 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is it possible to download a hws file to the PXI6534 with c++? If yes, how?
Or, any suggestions on how to generate SPI-data from c++ to a PXI6534.
0
Kudos
Message
1
of 2
(3,450 Views)
Reply
Re: How do I with c++ generate SPI from a PXI 6534 ?
Jimmie_A.
NI Employee (retired)
01-24-2006
04:58 AM
- last edited on
02-13-2025
03:50 PM
by
Content Cleaner
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello!
I haven't found a finished example that shows how this can/could be done.
However I found some information that might be helpful for you:
How can a DIO card generate SPI data
http://forums.ni.com/ni/board/message?board.id=70&message.id=3010&requireLogin=False
Has anyone been able to communicate via SPI from a DAQ card?
http://forums.ni.com/ni/board/message?board.id=250&message.id=8001&requireLogin=False
NI DIO 6534 pattern output
http://forums.ni.com/ni/board/message?board.id=70&message.id=1108&requireLogin=False
Also I would like to point out that we have a new USB device that is a IC2 and SPI Interface:
https://www.ni.com/en-us/support/model.usb-8451.html
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
0
Kudos
Message
2
of 2
(3,368 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
