Digital I/O
How do I write a channel with usb 6008,Visual Studio 2010, NI-DAQmx?
I have a NI-USB-6008. I am using Visual Studio 2010, Visual C#, .Net 4.0.
I have tried several things, also i took a look into the examples, but the example WriteDigChan.2010, in ...\Documents\National Instruments\NI-DAQ\Examples\DotNET4.0\Digital\Generate Values\WriteDigChan\CS
It works just when i don't select a chanel to write, by default its written Dev1/Port0/line0:7 when I click write it sends the information, but when I select for example Dev1/port0/line1 it shows me a window with the next information:
Specified read or write operation failed, because the number of lines in the data for a channel does not match the number of lines in the channel... etc etc
What can I do? Really I have no idea.
(4,443 Views)
Good morning. I´m José Manuel Vólquez, an Application Engineer from National Instruments México. The problem here is in the moment when the acquisition task is created. I´m your code you must have a function similar to:
DAQmxCreateDOChan (taskHandle, chan, "", DAQmx_Val_ChanForAllLines);
The last parameter is the problem; you must select the option “One Channel For Each Line” instead of “One Channel For All Line”.
Try to implement this change please.
Regards.
(4,427 Views)
Hi, could you check the solution that I recommended?
Regards.
(4,347 Views)
Thank you so much it worked really fine =D
(4,326 Views)
