Digital I/O
how do use ft245 in labview (write & read) +block diagram
(5,494 Views)
You obviously clicked the 'Post' button before you entered anything into the message body. Please try again. You have to provide some details. A major detail that is missing is what is a ft245? It's obviously not an NI Digital I/O board so also explain the reasoning of posting to this board.
(5,484 Views)
hi
tanks for reply . i have a missing in write & read with ft245 ( usb to parallel converter ) .
please help me for use function in block diagram . i use labview 2009 . tanks a lot
(5,442 Views)
Have you tried the examples from FTDI? I know they work with the FTDI serial chip. I have no idea what you mean by "i have a missing in write & read".
(5,429 Views)
HI
I HAVE PROBLEM WITH LABVIEW SOFTWARE IN BLOCK DIAGRAM .
WHAT DO I USE FUNCTION IN BLOCK DIAGRAM FOR CONFIG FT245 IN LABVIEW .
WHAT TOOLKIT OR FUNCTION ?
WRITE &READ = SEND TO FT245 & Recive OF FT245 .
HELP ME FOR FUNCTION BLOCK
TANKS A LOT
(5,417 Views)
Don't shout.
The link was incorrect though you should have been able to fix it. Try this. There are examples there that will open, write, and read. Try them and post back with something more specific.
(5,408 Views)
hi, i have checked the examples, but have anybody done a example with this drivers, please post it????
(4,881 Views)
