Home
Community
Discussion Forums
Most Active Hardware Boards
Digital I/O
Topic
Digital I/O
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How do you do a timed DIG out on a PCI-6025E board?
abradamn
Member
03-06-2004
02:49 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Im using a 4 channel DI/O of known frequency and duty cycle, and need a timed output on a PCI-6025E board.
0
Kudos
Message
1
of 2
(3,127 Views)
Reply
Re: How do you do a timed DIG out on a PCI-6025E board?
Jeremy_L
NI Employee (retired)
03-08-2004
12:23 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi abradamn,
I dug around and found a few examples that may help you:
Continuously Generating Digital Pattern Output
Which DIO Ports to use on 6025E card
I'm not quite clear on the wording of your question. Are you asking about having 4 timed channels of digital output, or a single channel of output, with 4 channels of input?
Also, it might be a good idea to initialize your Digital Ports prior to use. Here is a good document on how to do it.
Setting Default State of Digital Lines on E Series Boards
Hope this helps!
Jeremy L.
Jeremy L.
Kudos
Message
2
of 2
(3,127 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
