Digital I/O
How do you do a timed DIG out on a PCI-6025E board?
Im using a 4 channel DI/O of known frequency and duty cycle, and need a timed output on a PCI-6025E board.
(3,126 Views)
Hi abradamn,
I dug around and found a few examples that may help you:
Continuously Generating Digital Pattern Output
Which DIO Ports to use on 6025E card
I'm not quite clear on the wording of your question. Are you asking about having 4 timed channels of digital output, or a single channel of output, with 4 channels of input?
Also, it might be a good idea to initialize your Digital Ports prior to use. Here is a good document on how to do it.
Setting Default State of Digital Lines on E Series Boards
Hope this helps!
Jeremy L.
Jeremy L.
(3,126 Views)
