Digital I/O
How to Acquire 16bit Samples not in 16byte block
hello
I use PCI 6534 board
I have to read few samples of 16 bit  synchronizes with external clock ~120kHz receive from device
the source device send to board 1-256 clock samples.
the board read in continues mode
If i used DMA setup i read 16bytes block
if i used interrupt setup i can't read up to 16 byte.
at both setup i miss the last clock sample
How can i read  exactly count of samples that Device send?
best Regards,
Eran
(3,226 Views)
Hey Eran,
I need more information about your application in order to address the issues you've been having.  How have you set up the application?  Are you acquiring all of the samples simultaneously?  What exactly is the behavior you experience with you use interrupts as the data transfer method?  Are you using LabVIEW to acquire the data?  Could you provide a code sample or a brief explanation or the application's architecture?  Any other pertinent information you can think of would be useful.
Elijah Kerry
NI Director, Software Community
(3,206 Views)
