12-31-2006 09:58 AM
01-02-2007 03:51 PM
Hey Eran,
I need more information about your application in order to address the issues
you've been having. How have you set up the application? Are you
acquiring all of the samples simultaneously? What exactly is the behavior
you experience with you use interrupts as the data transfer method? Are
you using LabVIEW to acquire the data? Could you provide a code sample or
a brief explanation or the application's architecture? Any other
pertinent information you can think of would be useful.
