Digital I/O
How to control NI USB-6509 with Micrsoft Excel Macro?
I recently brought NI USB-6509 (96 channel USB to Digital IO) and tested ok with Labview. But i wanted to detect and control the same device in microsoft excel. Can anyone suggest me some solutions to work on excel with this device?
(6,957 Views)
Accepted by topic author Boosa
Look here and here. For other examples, do a search for 'DAQmx VBA'.
(6,946 Views)
Hello Dennis,
That was very useful for me to start with the instrument.
I have a problem where the device is resetting after every read.
My application is to read the entire port and modify one bit in the port. Here is how i am doing the activity
Step 1 : Create Task handle for both write and read activities
Step 2 : Read the port and store in buffer
Step 3 : Modify read buffer
Step 4 : Send the modified data to same port (bit modification)
This works fine first time. When i repeat the same from Step 2, all ports are getting reset to defualt values instead of previous data.
I am absolutely blank why device is resetting when i am reading.
I will be thankful to you if you could help me in this.
I am also attaching VB code for your reference.
(6,877 Views)
