Digital I/O
Wiring NI 9472
How should I wire a 9472 in a cRIO-9022 chassis?  The schematic is simple, but I am afraid of giving it too much current or too little voltage.
My power supply is WP-706B (http://www.plccenter.com/en-US/Buy/VECTOR%20VID/WP706B) and the positive of course to Vsup and ground to COM.  The power supply give a current readout that is really high before I get to the 6V minimum for the module.
It is hard to test because I do not want to fry the module.
Any suggestions?
Thanks!
(6,207 Views)
Hi Jrevard,
Looking at the manual for the 9472, it looks like module has some short circuit protection to prevent the module from being damaged by high currents. I would recommend looking at page 14 and the table on page 18 in the manual, which explain the various currents that the module may be damaged by. I hope this helps!
David S.
(6,181 Views)
Thanks for the reply.  I think my problem lies more with the power supply.  It was explained to me that the current readout is what the supply is ABLE to give at that voltage. I study science and am super confused about current and voltage.  It seems so straight forward, but I always get confused when supplies are involved.  This thread may belong in an electrical discussion board.  My hope was that others had used a supply like this one and could explain what the load of the 9472 was "seeing."
Thanks again.
(6,076 Views)
Hi jrevard,
When you say the current readout, are you measuring the current with an external device? I think the supply you are using should be compatible with the 9472, although I would keep in mind this warning from the manual: "
If the power supply you are using with the NI 9472/9474 cannot supply more than 13 A, the module may be damaged if a short-circuit condition occurs."
If you do have more general questions on power supplies and things like that, I would suggest checking out some general electrical discussion boards like you mentioned.
David S.
(6,057 Views)
