01-30-2013 12:43 PM
How should I wire a 9472 in a cRIO-9022 chassis? The schematic is simple, but I am afraid of giving it too much current or too little voltage.
My power supply is WP-706B (http://www.plccenter.com/en-US/Buy/VECTOR%20VID/WP706B) and the positive of course to Vsup and ground to COM. The power supply give a current readout that is really high before I get to the 6V minimum for the module.
It is hard to test because I do not want to fry the module.
Any suggestions?
Thanks!
01-31-2013
04:06 PM
- last edited on
09-24-2025
02:41 PM
by
Content Cleaner
Hi Jrevard,
Looking at the manual for the 9472, it looks like module has some short circuit protection to prevent the module from being damaged by high currents. I would recommend looking at page 14 and the table on page 18 in the manual, which explain the various currents that the module may be damaged by. I hope this helps!
02-25-2013 02:58 PM
Thanks for the reply. I think my problem lies more with the power supply. It was explained to me that the current readout is what the supply is ABLE to give at that voltage. I study science and am super confused about current and voltage. It seems so straight forward, but I always get confused when supplies are involved. This thread may belong in an electrical discussion board. My hope was that others had used a supply like this one and could explain what the load of the 9472 was "seeing."
Thanks again.
02-26-2013 05:20 PM
Hi jrevard,
When you say the current readout, are you measuring the current with an external device? I think the supply you are using should be compatible with the 9472, although I would keep in mind this warning from the manual: "
If the power supply you are using with the NI 9472/9474 cannot supply more than 13 A, the module may be damaged if a short-circuit condition occurs."
If you do have more general questions on power supplies and things like that, I would suggest checking out some general electrical discussion boards like you mentioned.
