If you are rather an electronics newbie (we all have been in that situation at the beginning of our career), I would strongly recommend using a ready-made unit for your application. There are quite a few slotted optical sensors available. RS, for example, has comprehensive application documents on their slotted sensors. I cannot give you a link since I store these documents locally, but here is the title:
'Reflective and slotted opto-switches 2601'
There is also a document number in the header: 232-2447.
I think for your application a slotted sensor like RS stock number #304-560 would be suitable. All you have to add is a current limiting resistor for the LED, and you even do not need a torch... You will get TTL-compatible signals if you use a supply voltage of 5VDC (regulated, please).
In case you cannot place the cutout or slot for the opto switch conveniently (the depth of the slots of the mentioned sensors is limited to a few mm) I would suggest using a reflective opto switch (some are mentioned in the document). You should blacken the rotating disk and glue a small piece of reflective material (aluminium wrapping foil or chrome adhesive tape will do) on the disk such that it will pass in front of the sensor surface.
Sorry but I am neither a consultant nor a free-lance engineer. In case you need more detailed support you should apply to a consultant having some experience in optoelectronics.
