Digital I/O
How to measure the digital waveform
      iam using USB-6501 Digital I/O and get digital waveform (pulse) but i
can't measure pulseperiod, pulseduration, duty cycle, cycle avg, how to
get this requirment. ihave attached the vi.
(3,535 Views)
Keep in mind that the USB-6501 has static digital I/O timing.  This means that all of your measurements are software-timed, which is undeterministic.
The VI you posted cannot accurately measure period, pulse duration, or duty cycle.  There is no timing information in the digital waveform you are reading.  To perform these types of measurements you should be using a counter, not static digital I/O.
The USB-6501 has only one counter with limited functionality. In your program I notice that you are reading from multiple channels, so it sounds like you need a device that has more than one counter. If you are interested in upgrading to a device with multiple, full-functionality counters, I would suggest that you contact NI for a recommendation of what device will be best for your specific application at ni.com/contact.
There are example VIs that ship with LabVIEW demonstrating how to use counters to make the measurements you want to make.  Go to the Help menu in LabVIEW and select Find Examples....  This will open the Example Finder.  Look in the folder called Hardware Input and Output » DAQmx » Counter Measurements » Period or Pulse Width.  The examples found in this folder will allow you to perform the measurements you need using a counter.
I hope this helps!  Please let me know if you have any questions about the resources I suggested.
(3,514 Views)
