Digital I/O
How to program controlling of ten 12V solenoid valves by computer
Hi .... the exact problem is:
There are ten 12V solenoid valves. I want to open the valve1 at t1 time, valve2 at t2 time.....and so on where t1, t2 are variable time depending on my experiment when I want to open them. I know LabView can do the programming part to control this. What I want to know is what kind of hardware do I need as an interface between the ten 12V solenoid valves and the computer??
After solving this, there is one more problem : that is I want to send one output trigger of 5V from the same computer to another device exactly at the same time when the valve opens.
Thanks in advance ..!
(5,822 Views)
What kind of timing accuracy do you need? Is the margin of error in a relay going to be a problem?
Personally I'd drive a relay through a ULN2003A driver (or two) and switch the 12v through the relay.
(5,818 Views)
An error of 1ms is fine .... I don't know how much delay it takes through relay
by the way, the ten solenoid valves are connected to a wire (serial port wire) having 25 pins. Actually these valves and the wire are predesigned, so I need to control them via serial port (either directly through computer or via an interface between them).
Any suggestions ??
(5,813 Views)
Below I attached a picture where you may see the white serial port wire ...which is actually coming from the ten valves (and which pins triggger which valves that I can figure it out) ..
(5,812 Views)
Hello SDipt,
i dont know if i get it right: The Control Box that can be seen in the Picture has a DSub (25) Pin Plug. But is this a RS232 Interface or is just a similar Plug used and the Valves are controlled by applying 12V Signals to specific Pins?
When choosing Hardware there are a bunch of additional Questions that have to be answerd:
-What Interface do you intend to use? (USB, PCI ...)
-If i get it right there are no analog Signals to be measured here just digital Signals: (10 x 12V and one 5V) is this correct?
Best Regards!
Moritz M.
(5,790 Views)
