Digital I/O
How to read Digital I/O using PXI-7813R?
Yeah perhaps thats the reason. If it helps, when I try connecting the READ FIFO to a control, the broken wire explanation that comes up is that the FIFO is 'void' ?? And, now whatever I try, non of the wires get connected.
Am I right when I say I need to 2 FIFO's? One for Read and one for Write that will have to be configured seperately in the project?
Message 21 of 25
(2,927 Views)
Any one know how I can read out the data signal from the Host vi attached along with this?
I am trying to read a digital line from the PXI-7813R through the FPGA and control through the Host vi.
Message 22 of 25
(2,915 Views)
Message 23 of 25
(2,915 Views)
It looks like all you are missing is to wire up an indicator to the Data output of the DMA on the host.
Message 24 of 25
(2,899 Views)
I just wired up an indicator to the data ouput, but nohting shows up in the indicator. While I highlight the execution on the Host, an error signal seems to get highlighted. I have attacehd the Project again.
Message 25 of 25
(2,885 Views)
