Digital I/O
How to set a trigger pulse output to the PFI1 line in PXI-5102?
I have this problem: I have trigger pulses coming to the RTSI 0 of PXI-5102 and I use the pulses to trigger data acquisition. I also would want to trig other external devices with that same trigger pulse. This should be possible through PXI-5102's PFI1 line which is a smb-plug. I'm trying to use the export signal.vi to route the trigger pulses to the PFI but I get error messages which say "Invalid value for parameter or property." or if I use PFI0
"Invalid value for Configure Trigger Output Source."
What am I doing wrong?
I used LabView's "niScope EX Configured Acquisition.vi"-example and I only added there the export signal.vi.
D
(3,165 Views)
(3,113 Views)
