I have this problem: I have trigger pulses coming to the RTSI 0 of
PXI-5102 and I use the pulses to trigger data acquisition. I also would
want to trig other external devices with that same trigger pulse. This
should be possible through PXI-5102's PFI1 line which is a smb-plug.
I'm trying to use the export signal.vi to route the trigger pulses to
the PFI but I get error messages which say "Invalid value for parameter
or property." or if I use PFI0
"Invalid value for Configure Trigger Output Source."
What am I doing wrong?
I used LabView's "niScope EX Configured Acquisition.vi"-example and I only added there the export signal.vi.
D
