Digital I/O
How to use a USB 6525 to control RC servo (futaba)
I am looking to drive a futaba RC Servo using my USB-6525  is this possible and what is the best solution -I have labview 8.5
any help would be great
Rob
(4,064 Views)
Hi Rob,
With the 6525 you are ging to need an external source to drive the servo. I see the current limitation is 500 mA for the relay output and I believe most servos use more current than that, so I would not recommend it. You might try using a second external power supply and use the 6525 to trigger an external transistor to allow current to your servo.
Let me know how else I can help with this.
Nathan B
(4,044 Views)
