Digital I/O
generating and displaying digital output using USB 6008
Hallo all,
I am new to LabVIEW 🙂
I m having LabVIEW 2010 and LabVIEW SignalExpress für DAQ (in German) on my computer.
I would like to create a digital output of 2.1V voltage using USB 6008. What I have done so far is that I have added "DAQ Assistant" on Block Diagram and I have selected 2 digital output
What I want is to have the value of the digital out shown on a number indicator. Secondly I would like to fix the digital out to 2.1 Volt. How can it be done?
Any suggestion is appreciated
(4,630 Views)
Digital is either 0 (closer to 0.3v) for a low or 5v for a high.
If you want something else, either use the analog outputs or do some signal conditioning after the DIO ports.
(4,624 Views)
Unfortunately digital output is my only option. It would be great if you could show me what function do i need (i.e. from the palette) that i need to do the conditioning. All I want is to limit it to 2.1 V
And how do I display (or rather, check) the output value on LabVIEW VI itself?
(4,613 Views)
Labview does not have any functions that will change the output voltage of the USB-6008.  You will need to add an additional circuit to do this.  The digital output of the USB-6008 has a pull-up resistor (4.7K) to 5V.  A simple voltage divider should work.  You may want to add a voltage follower to minimize the effects of the circuitry after the divider on the output voltage.  See attached circuit for reference.
(4,609 Views)
Thanks for the suggestion.
And what abut displaying the digital output? i tried to wire it to a numerical display on labVIEW but it did not work.
And I would like to ask for some explanation in reference to the screenshot below. What are all the circles for the binary value for? I can switch on or off the circle but i dont understand the effect of it. Is it controlling the digital output? If so i would like to know how to show the current output value
(4,600 Views)
You seem to have some basic misunderstanding about digital logic. An output is either a 0/1  or True/False. This is indicated normally with a Boolean indicator. A digital control like you show, is set with Booleans - True/False for each line.
(4,594 Views)
