Digital I/O
How to use the PCI-6534 onboard memory ?
Hi MES,
Sorry for such a delayed reply.  Before I was under the assumption that the DAQmx_Val_WhenAcqComplete property was definitely available to use, but in fact it is not in this case.  I was told that because you are doing a finite acquisition, the device automatically waits until all the samples are acquired before transferring the data.  This would make using the property unnecessary.  I'm still trying to come up with a way to test this out, possibly by viewing the buffer during a finite acquisition and seeing when the data is transferred.  I'll let you know what I find out.
Justin M
Message 21 of 22
(1,330 Views)
Thanks for the information!  We were starting to assume that here.  That's good news to hear.
Message 22 of 22
(1,323 Views)
