Digital I/O
I am using LV5.1 and a DAQ-card Computerboards "CIO-DO96H" (DO-card) since years.
Is it possible to readback the outputstatus in LV 5.1?
(3,606 Views)
Chris:
The answer to this question depends on the hardware you are using and also the driver software that LV is interfacing(supplied by Computerboards). The best thing is to check with them to see if the hardware and device driver supports readback functionality on the output ports.
June
(3,606 Views)
