Digital I/O
Incorrect header for niHSDIO_HWC_FetchSampleErrors?
Hi.  Most of my test program is working well, but I seem to be having a problem with the niHSDIO_HWC_FetchSampleErrors prototype.
Here is the function prototype from the niHSDIO.h include file:
  ViStatus _VI_FUNC niHSDIO_HWC_FetchSampleErrors(
     ViSession vi,
     ViInt32 numSampleErrorsToRead,
     ViInt32 maxTimeMilliseconds,
     ViInt32* numSampleErrorsRead,
     ViReal64 sampleNumber[],
     ViUInt32 errorBits[],
     ViInt32 errorRepeatCount[],
     ViUInt32* reserved1,
     ViUInt32* reserved2);
Here is the exception detail that I captured:
  Exception caught
  Detail:  [Error -1074135024] Windows Error 0xBFFA0010
  DLL Description:  Invalid value for parameter or property.
  Parameter 8 out of range, or error occurred while setting Parameter 8.
I believe this is referring to either reserved1 or reserved2.  I am passing pointers to a unsigned longs initialized to "0" in both cases.  What should be here?
Also,  the help file in LabView 8.5 has does not have a correct description for this function (it is missing a parameter):
  ViStatus niHSDIO_HWC_FetchSampleErrors (
     ViSession vi,
     ViInt32* numSampleErrorsToRead,
     ViReal64[] sampleNumber,
     ViUInt32[] errorBits,
     ViInt32[] errorRepeatCount,
(when I tried to use the help file's definition, the system complained about missing 4 bytes of passing arguments so I assume the niHSDIO.h file's reference is more accurate.)
(3,906 Views)
Accepted by broke
My colleague found that all of the example "C" code using this function passes NULL to the "reserved" parameters (instead of a pointer to ViUint32 variables). When NULL is passed to the 2 reserved parameters instead of a pointer, then the code runs without raising an exception. (And the 3 arrays "sampleNumber", "errorBits", and "errorRepeatCount" do return meaningful data...)
Perhaps I don't understand C as well as I should, but I would think there would be another way to declare the two reserved parameters in the include file so that it is more clear that NULL must be passed...
(3,875 Views)
I think that this is one of the cases where the function prototype was developed with extra inputs/outputs that were taken out at some point, or this function was created with scalable functionality. I think that if you pass in NULL for those two inputs to the function it should work properly. I have a feeling that you were getting an out of range error because it wasn't actually expecting a real value as an input. Give that a try and let us know the results.
Oops I guess I posted too late...
Message Edited by Chris W. on 01-29-2009 05:48 PM
(3,871 Views)
