Digital I/O
Individually access inputs and outputs on single port (PXI-6509
I'm using PXI-6509 and this sentence from the manual:
"You can use each of the DIO lines as a static digital input (DI) or digital output (DO) line,"
leads me to believe that each individual DIO can be set as input or output (even within ports), but theimage:
shows that these ports cannot be set as inputs and outputs within the same port.
On another card 6284, with DIO's, I can set them individually.
Can someone confirm that the 6509 is acting correctly?
Best Regards,
Adrian
Message 1 of 14
(7,160 Views)
If you create a task then it appears you can control an individual DIO line.
Message 2 of 14
(7,145 Views)
Using the 6509, I have had inputs and outputs on the same port.  I'm not sure why the Soft Front Panel is not letting you do that.
Message 3 of 14
(7,142 Views)
Hi guys,
Thanks for the feedback.
How I found the problem was as follows:
  • I created 2 virtual channels as input (P6.6 and P6.7)
  • I created 6 virtual channels as output (P6.0 to P6.5)
  • Using a single digital write (DAQmx VI) I energize the coil on a relay using one of the outputs
  • Using a single digital read (DAQmx VI) I read the state of P6.6 and P6.7. As soon as I read either of these ports, the coil is de-energized and it would seem the whole port is set as input even while I am attempting to do these things separately.
(Is my approach OK?)
So after this I went to look at the soft panels and saw there that the lines were not individually controllable.
It certainly feels wrong that this could be the case.
Thanks again,
Adrian
Message 4 of 14
(7,119 Views)
Hi ARL00000000000…,
I experienced the same behavior in the test panel.  I'm doing more research to determine if this is correct behavior.
Message 5 of 14
(7,099 Views)
Hi Defective,
Have you had any luck with this issue?
It still seems weird that it would be the case.
Adrian
Message 6 of 14
(7,071 Views)
Hi Adrian,
I looked up the product page of the device and found the following information: line direction selectable on an 8-bit port basis (https://www.ni.com/en-us/support/model.pxi-6509.html).  This is consistent with what you are seeing in LabVIEW and NI MAX.
Message 7 of 14
(7,044 Views)
Hi Luke,
Thanks for the reply. Unfortunately the link posted leads to a "Sorry, page not found".
Best Regards,
Adrian
Message 8 of 14
(7,030 Views)
@ARL00000000000000 wrote:
Hi Luke,
Best Regards,
Adrian
He had an error with the URL. Easily corrected if you had observed what was in the URL box in your web browser.
Message 9 of 14
(7,019 Views)
@Defective_Luddite wrote:
Hi Adrian,
I looked up the product page of the device and found the following information: line direction selectable on an 8-bit port basis (http://sine.ni.com/nips/cds/view/p/lang/en/nid/13261).  This is consistent with what you are seeing in LabVIEW and NI MAX.
On page 3 of 10 of the linked Data Sheet, it states You can individually program each 8-bit port on an NI 6509 to be input or output
That is very very confusing.
Message 10 of 14
(7,015 Views)
