Digital I/O
Using MAX to configure digital input levels on a USB-6009
I'm using a USB-6009 in a Windows environment. MAX lets me configure the 8 bits in port 0 as either input or output. However, when I set the bits to be all inputs, their default level is high, and the "ALL LOW" button is grayed out. Is there a way I can activate this button to set all input bits low and so be set to read a +5V input pulse?
Regards
Geoff Hammond
(4,617 Views)
Accepted by Dennis_Knutson
When you configure the pins as inputs, you can read either 0 or 5 volts. It does not make any sense to set then high or low. Any pin that is disconnected will of course sense a logic 1 because of the pull-ups on the device.
(4,615 Views)
Of course; thank you.
Geoff
(4,605 Views)
