Digital I/O
Is NI-9381 compatible with cDAQ-9188?
When I connect the NI 9381 module to cDAQ-9188. NI MAX reports unsupported module. Does that mean NI 9381 and cDAQ-9188 are uncompatible?
I looked at this but it's not clear if this is specific to LabView.
https://www.ni.com/en-us/support/documentation/supplemental/08/c-series-module-and-compactdaq-compac...
(1,914 Views)
Accepted by tonynguyen
NI 9381 is not compatible with any cDAQ. It is only compatible with cRIO, which requires a different hardware and driver. The web page you referenced applies to all compatible programming language supported by these devices.
(1,855 Views)
