Digital I/O
Is there a module that can create a differential signal for cRio?
I see there are modules that can input a differential signal (NI 9411), but I haven't found a module that can output a differential signal. Is there a module capable of creating a differential signal? Thanks
(4,275 Views)
Hi C Painter,
To answer your question, an NI signal generator that is configured for differential output generates waveforms via two complementary signals. Each of these signals is generated at a different differential output connector according to the Signal Generator Help: http://zone.ni.com/reference/en-XX/help/370524M-01/siggenhelp/fund_differential_output/
If you can elaborate some more on your application, I may be able to provide you with a more appropriate answer. Thanks!
-Carisa
(4,264 Views)
